24th September 2025
Early update 139-b-001 is now available for CXN100.
- Added support for Qobuz Connect.
4th August 2025
Early update 138-b-013 is now available for CXN100.
- Improved display font style and size for better readability from a distance
- You can now save your EQ setup and easily switch between your custom EQ presets whenever you like
- Fixed an issue on the Now Playing screen on some tablet models.
- Fixed stability issues during product setup on Android 7 devices.
- Fixed an issue where preset images did not always load.
- Fixed an issue where the selected preset was not always highlighted after reopening the EQ section.
6th May 2025
Early update 138-b-003 is now available for CXN100.
- Improved Audio Settings – a smoother and more intuitive interface
- EQ Toggle – option to disable the EQ completely
- Bug Fixes– better performance and stability
20th March 2025
Early Update 138-b-002 is now available for CXN100.
- Add Room compensation feature
- Add 7 band EQ and presets feature
- Add Balance control
- Add Amazon Music service integration
- Update to TIDAL Connect SDK 1.5.0
- Fixed: Customer unable to see artwork on CXN100 with files from a USB drive
- Fixed: Unit cannot be factory reset when streaming TIDAL Connect
- Fixed: After 3x fast SM App standby button presses the unit becomes unresponsive and eventually crashes and reboots
18th November 2024
Early Update 136-b-017 is now available for CXN100.
- Fix for freeze/crash with some internet radio stations
- Show correct "Listening on" info when using QPlay
5th November 2024
Early Update 136-b-015 is now available for CXN100.
- Added QPlay support
- Fixed: Volume is attenuated when skipping TIDAL and YouTube Music tracks via AirPlay
- Fixed: Recalling UPnP Server (Window Media Player) preset queue tracks but doesn't start playback
- Fixed: AirPlay icon and "Paused" animation are displayed when skipping AirPlay tracks
- Fixed: Cannot playback Minim Server queue preset
- Update SCD/Cast to latest version
- Fixed: Queue didn’t update on queue screen after adding items
- Fixed: Source name was blurry on the front panel display
- Change: VU Meter design change based on initial feedback
- Fixed: CBus can stop working after a long period in Standby
- Fixed: Noise while playing DSD512 on CXN100
- Fixed: Issues turning on from preset after main power cycle
- Updated: New Splash screen animation for CXN100
28th October 2024
Early Update 136-b-013 is now available for CXN100.
18th October 2024
Early Update 136-b-012 is now available for CXN100.
30th May 2024
Early Update 134-b-008 is now available for CXN100.
- Avoid random preset 0 appearing
- Change "Chromecast built-in" to "Google Cast" and add dark mode logos
- Fix Control4 device discovery
- Stretch small artwork images
- Swap repeat and shuffle icons order
- Fix potential hang on the Japanese TIDAL Connect prompt
- Improve display layout in various languages
- Add spaces around Spotify/TIDAL URLs to help display layout
21st May 2024
Early Update 134-b-006 is now available for CXN100.
- Updated user interface
- Added VU meters
- Added time screen
- Added ability to view different now playing screens for each source
- Improved info screen
- Improved software update screen
- Updated Deezer logo
- Updated TIDAL Connect
- Updated Spotify
- Updated Roon
- Updated webmin setting page
- Improved Windows Media Player DLNA playback
- Fixed Media Player metadata missing following power cycles
- Fixed no audio after re-connecting to Spotify
- Improved Chromecast setup in foreign languages
- Fixed Control4 queue management
- Fixed display glitches when playing certain Media Library playlists
- Fixed low sample rate playback on digital inputs
- Improved .WAV file metadata parsing
- Fixed SM App album artwork when playing .M3U playlists
- Fixed an issue connecting to Wi-Fi following multiple power cycles in quick succession
- Fixed no audio after enabling "TV mode" and then switching to other sources
- Added ability to re-order presets
14th February 2024
Early Update 133-b-014 is now available for CXN100.
- Adjusted power-on mute relay timings
