| Product | Win 7 or earlier | Win 8,8.1 | Win 10,11 |
| Azur 751R | 1.67 | 5.12.0 | 5.27.0 or newer |
| Azur 751R v2 | 1.67 | 5.12.0 | 5.27.0 or newer |
| Azur 851C | 1.67 | 5.12.0 | 5.27.0 or newer |
| Azur 851D | 1.67 | 5.12.0 | 5.27.0 or newer |
| Azur 851N | 1.67 | 5.12.0 | 5.27.0 or newer |
| CXA61 | Limited support | 5.12.0 | 5.27.0 or newer |
| CXA80 | 1.67 | 5.12.0 | 5.27.0 or newer |
| CXA81 | Limited support | 5.12.0 | 5.27.0 or newer |
| DacMagic 100 | 1.67 | 5.12.0 | 5.27.0 or newer |
| DacMagic 200M | Not supported | 5.12.0 | 5.27.0 or newer |
| DacMagic Plus | 1.67 | 5.12.0 | 5.27.0 or newer |
| DacMagic XS | 1.67 | 5.12.0 | 5.27.0 or newer |
| Edge A | Not supported | 5.12.0 | 5.27.0 or newer |
| Edge NQ | Not supported | 5.12.0 | 5.27.0 or newer |
| Evo 150 | Not supported | 5.12.0 | 5.27.0 or newer |
| StreamMagic 6 | 1.67 | 5.12.0 | 5.27.0 or newer |
| StreamMagic 6 v2 | 1.67 | 5.12.0 | 5.27.0 or newer |
If you own a DacMagic100, DacMagic Plus, 851C manufactured before 2014 you may need to upgrade its USB first to enable USB Audio 2.0 compatibility.
Driver Download
Our range of drivers can be downloaded from our Driver Updates page
DRIVER RELEASE NOTES [V5.27.0]
8th December 2021
- The Windows USB Audio class 2 driver (v5.27.0) has recently been updated.
- There is no new product support added to this version, but there is a security fix for Windows 10 and support added for Windows 11.
- Changes from v5.12.0 to v5.27.0 (these are mostly issues hidden):
Fix: Fixed a security vulnerability (update recommended)
- New: support for Windows 11 (21H2)
Change: now using SignTools 1.9 - New: support for Windows 10 (21H1)
- New: API version 5.8
- Change: Operating systems Windows 7, Windows 8 and Windows 8.1 are no longer supported (Microsoft discontinued vendor signing)
