VIA FRONT PANEL CONTROLS
- Connect USB SSD, HDD or flash drive to either to front panel or rear panel USB Input.
- Press the Home button on the front panel, then navigate to Music Library.
- Within the Music Library locate the USB device and select the track, album or folder you wish to playback.
- Upon selecting a track you will have the option to ‘PLAY FROM HERE’, ‘PLAY TRACK NOW’, ‘PLAY TRACK NEXT’, or ‘QUEUE TRACK’.
VIA STREAMMAGIC APP
- Connect USB SSD, HDD, or flash drive to either to front panel or rear panel USB Input.
- Navigate to the Library tab of the StreamMagic app.
- Under USB Drives, locate your USB Media device and open it.
- Upon selecting a track you will have the option to ‘PLAY FROM HERE’, ‘PLAY TRACK NOW’, ‘PLAY TRACK NEXT’ or ‘QUEUE TRACK’.
Playback Options:
PLAY FROM HERE – Playback of the album/folder will begin from this point onwards.
PLAY TRACK NOW – The selected track will playback immediately.
PLAY TRACK NEXT – The selected track will be added to the queue and playback next.
QUEUE TRACK – The selected track will be added to the playback queue.
