1. Connect both of the supplied Wi-Fi antennas to the rear of the unit and ensure that it's in range of your wireless router
Then power on your unit.
Note: If you are setting up your device for the first time or after a factory reset, you will first need to follow the on-screen instructions to select your preferred language after powering on your unit.
2. Download and install the StreamMagic app from the Google Play store
StreamMagic app
3. Open the StreamMagic app and select ‘Connect’
4. Under Choose a device select 'Set up a new device' and then select the name of your Network Player
5. Select ‘Wireless Connection’ and then 'Continue'
6. Your Android device will now show all available Wi-Fi devices in the range
Select the name of your Network Player.
7. Once connected, you will be prompted to enter your Wi-Fi network password
Enter the password and select 'Continue'.
8. Your device will now connect to your Wi-Fi network, this may take up to a minute
9. Once connected, complete the initial setup of your unit within the StreamMagic app
