There are two ways of performing a factory reset on the CXN100:
Via the front panel:
- Hold down the ‘i’ (Info) button on the front panel.
- As instructed on the display, hold down the ‘reverse skip’ button to perform the factory reset.
Via the StreamMagic app:
- Once the StreamMagic app is connected to the CXN100, select the device ‘Settings’ option.
- Select ‘Factory Reset’.
- Select ‘Continue’.
Please note that a reset will delete all saved settings, presets, and network information.
