With Pre-Amp mode enabled within the StreamMagic app device settings, the volume of the device's analogue outputs can be controlled using the StreamMagic app or rotary dial.
Notes:
- Pre-Amp mode and volume control can only be enabled when connected via the analogue outputs.
- The rotary dial will not have a function when Pre-Amp mode is disabled.
