12th February 2026
Early update 022-a-169 is now available.
- Resolved an issue that could cause the app to crash when the queue was loaded repeatedly.
- Improved stability for long TIDAL playback sessions. TIDAL has made improvements to extend the timeout, which may reduce the need to reconnect. A full fix is still pending.
27th January 2026
Early update 022-a-168 is now available.
- Enabled Qobuz Connect support
- Fixed an issue where long track titles were truncated in SpMetadata
- Fixed an issue where long album titles were truncated in SpMetadata.
- Fixed an issue where long artist names were truncated in SpMetadata.
- Made non-functional performance optimisations to a few frequently called code paths.
30th May 2024
Early update 022-a-151 is now available.
- Fix the default unit name
- Avoid random preset 0 appearing
23rd May 2024
Early Update 022-a-149 is now available.
- Fixed APD behaviour during BT100 playback
- Added ability to re-order presets*
*StreamMagic App Beta version 2.14.0 or later required
