D/A CONVERTERS
Dual Wolfson WM8740 24-bit DACs
ANALOGUE FILTER
2-Pole Dual Differential Bessel Double Virtual, Earth Balanced
THD @ 1kHz 0dBFs
<0.001% 24-bit (at volume set to full)
THD @ 1kHz -10dBFs
<0.001% (at volume set to full)
THD @ 20kHz 0dBFs
<0.002% (at volume set to full)
FREQUENCY RESPONSE
20Hz-20kHz +/- 0.1dB *
SIGNAL-TO-NOISE RATIO
-112dBr (at volume set to full)
TOTAL CORRELATED JITTER
< 130pS
CROSSTALK @ 1kHz
< -100dB
CROSSTALK @ 20kHz
< -90dB
DIGITAL OUTPUTS
S/PDIF Coaxial: 16/24-bit, 32-192kHz
TOSLINK Optical: 16/24-bit, 32-96kHz
AUDIO FORMATS
WAV containing uncompressed, PCM 16-24 bit 32-192kHz, FLAC containing losslessly compressed, PCM 16-24 bit 32-192kHz, Apple Lossless (ALAC) containing losslessly compressed PCM 16-24 bit 32-192kHz, AIFF containing uncompressed, PCM 16-24 bit 32-192kHz, Microsoft® Windows Media TM Audio (WMA 9 Standard) 32-320kbps, MP3 (CBR or VBR) 16-320kbps, AAC, HE AAC and AAC+, (CBR or VBR) 16-320kbps, OGG Vorbis 32-320kbps.
STREAMING PROTOCOLS
RTSP (Real Time Streaming Protocol), MMS (Microsoft Media Server Protocol), HTTP (Hyper Text Transfer Protocol).
CONNECTIVITY
UPnP, Local USB media, Airplay 2, Chromecast built-in, Internet Radio, Spotify Connect, TIDAL, Qobuz, Roon Ready.
PLAYLIST
ASX (Microsoft® playlist format) M3U, PLS
WI-FI
IEEE 802.11 b/g or n (2.4GHz only)
WI-FI ENCRYPTION
WEP, WPA, WPA2
ETHERNET
USB
3 x USB 1.1 current limited to 1A each
FILE SYSTEMS
FAT32, NTFS
MAINS INLET VOLTAGE
100-240 VAC (switch mode)
STANDBY CONSUMPTION
<0.5W
MAX POWER CONSUMPTION
30W
DIMENSIONS
85 x 430 x 305mm (3.4 x 16.9 x 12.2")
WEIGHT
4 Kg (8.8lbs)
