Pressing this button allows the DacMagic 200M to receive wireless Bluetooth audio from most phones, tablets, and laptops.
To pair a new BT device with the DacMagic 200M you need to:
- Make sure any previously paired BT device is turned OFF (this product will auto-connect to the last paired device).
- Turn on Dac Magic 200M and select BT as a source.
- Activate BT on the source device.
- Scan for available devices on the source device and select 'DacMagic200M'.
