AXR85
Power output: 85 watts (into 8Ω)
THD (unweighted):
<0.01% @ 1kHz, 80% of rated power
<0.15% 20Hz - 20kHz, 80% of rated power
Frequency response (+/-1dB): 5Hz - 50kHz
S/N ratio (ref 1W): >82dB (unweighted)
Input impedances: 47k ohms
Power Amp damping factor: >50
Standby power consumption: <0.5W
Max. power consumption: 500W
Bass/Treble controls: Shelving, ultimate boost/cut +/- 10dB @ 100Hz and 20kHz
Subwoofer output: 200Hz 2nd order L+R Level follows volume setting
Dimensions: 110 x 430 x 340mm (4.3 x 16.9 x 13.4”)
Weight: 8.1kg (17.8lbs)
Bluetooth: 5.0 A2DP/AVRCP supporting SBC
TUNERS
Bands:
European
- AM (522-1629kHz)
- FM (87.5-108MHz)
US
- AM (530-1710kHz)
- FM (87.5-108MHz)
Aerial inputs: FM 75 ohms, Coaxial. AM 300 ohms wire loop/ single wire.
Signal to noise: 60dB typical (FM)
Distortion: <0.4% @ 1kHz 50kHz deviation (FM mono)
<0.6% @ 1kHz 50kHz deviation (FM stereo)
AXR100
Power output: 100 watts (into 8Ω)
THD (unweighted):
Frequency response (-1dB): 5Hz - 50kHz
Max. power consumption: 550W
Digital inputs:
- PCM 16-24-bit
- S/P DIF Co-axial 32-192kHz
- TOSLINK Optical 32-192kHz
TUNERS
Bands:
European
- AM (522-1629kHz)
- FM (87.5-108MHz)
US
- AM (540 - 1700kHz)
- FM (88 - 108MHz)
