Turntable Type:
Direct drive.
Turntable Speeds:
33 1/3, 45 RPM.
Torque:
1.6 kg/cm.
Wow, and Flutter:
<0.1%
Platter Material:
POM (Polyoxymethylene).
Platter Diameter:
305mm.
TONEARM
Type:
Static balanced tonearm with removable headshell.
Effective Length:
221.5mm.
Overhang:
19mm.
Effective Mass:
19.6g.
INTERNAL PHONO STAGE
Gain @ 1kHz:
42dB.
Nominal Output (supplied cartridge):
250m Vrms.
Equivalent Input Noise (A-weighted):
0.1u Vrms.
RIAA Curve Accuracy:
+/-0.3dB 30Hz-20kHz.
Signal/Noise Ratio (Ref 1V OUT, 20-20K BW):
90Db.
*THD+N 1kHZ:
0.0025%.
Input Impedance:
47kΩ.
Input Capacitance:
330pF.
OUTPUTS
Audio Output:
RCA phono/line level (switchable).
Bluetooth:
SBC/aptX/aptX HD.
GENERAL
Power Supply:
AC 100-240V, 60/50Hz.
Power Consumption:
5.5W Approx., 20W max, <0.25W (Standby).
Dimensions ( W x H x D):
435 x 139 x 368 mm.
Weight:
10.9 kg.
Cartridge
Type:
High output moving coil.
Frequency Response:
+/- 1dB 30Hz-20kHz.
Stylus:
Elliptical.
Cantilever:
Aluminum.
Output Level:
2mV @ 1kHz.
Recommended Tracking Force:
2g.
Recommended Load:
47kΩ.
