When deciding on a third-party cartridge to use with your Alva TT V2 there are a few factors that you may wish to consider:
Applicable cartridge weight range: Between 2.5g and 10g.
Max cartridge height for the TTV2: 16.4mm
Internal phono stage input impedance: 47kΩ
Internal phono stage input capacitance: 330pF
