EVO 75
The Alva TT V2 can be used alongside the Aux input on the EVO 75.
Set the output level switch on the rear of the Alva TT V2 to 'Line'.
Connect the output leads from the Alva TT V2 to the 'Aux In' on the EVO.
Set the ground switch on the rear of the EVO to '2'. This position can be beneficial in reducing hum with a turntable connected.
EVO 150
The Alva TT V2 can be used alongside the Aux input and the MM Phono input on the EVO 150.
Aux In
Set the ground switch on the rear of the EVO to '3'. This position can be beneficial in reducing hum with a turntable connected.
MM Phono
Set the output level switch on the rear of the Alva TT V2 to 'Phono'.
Connect the output leads from the Alva TT V2 to the 'MM Phono' input on the EVO.
Connect the ground lead from the Alva TT V2 to the ground screw on the EVO.
