You can use M1+ for up to 9 hours on one charge with a further 36 hours within the charging case.
Please note, however, this time may be reduced by several factors including:
High volume levels
Always using one earbud as the master version
Swapping the master between left and right occasionally will ensure that one earbud does not deplete at a faster rate than the other.
Using the highest possible codec
Using AptX or AAC may deplete the battery quicker as more data is being transferred between your device and Melomania 1+. If you can restrict your device to SBC only, you may experience longer listening time.
Audio Mode
'High Performance' mode gives you the best quality earphones sound experience, with a listening time of up to 7hrs (earphones) and 35hrs (total case + earphones).
'Low Power' mode extends listening time to up to 9hrs and 45hrs in total.
The option to switch between these modes can be found within the Melomania app under Settings.
