You can use Melomania 1 for up to 9 hours on one charge with a further 36 hours within the charging case.
Please note, however, this time may be reduced by several factors including:
High volume levels
Always using one earbud as the master version
Swapping the master between left and right occasionally will ensure that one earbud does not deplete at a faster rate than the other.
Using the highest possible codec
Using AptX or AAC may deplete the battery quicker as more data is being transferred between your device and Melomania 1. If you can restrict your device to SBC only, you may experience longer listening time.
