Your Melomania 1+ can be turned off in two different ways:
- Hold the button on both earphones at the same time for 3 seconds.
- Place them in the charging case and ensure that the LED on both earphones is “breathing” white. This signals that they are powered off and charging, ready for next use.
- APD (auto power down) will occur after ten minutes when disconnected from your device. If your Melomania 1+ is paired to your device and there is no audio transmission for 1 hour, the buds will APD.
