To enable you to play all tracks from a connected USB hard drive on your CXR, just follow these three steps.
1. Create a folder called 'Music' at the top level (root) of your USB hard drive
2. Move all music on your drive into this new folder
3. Once the USB drive is connected to your player, you will have the option to play all the tracks by navigating to Music Library > \[USB Drive Name\] > and pressing play on the Music folder
