To enable you to play all tracks from a connected USB hard drive on your CXR, just follow these three steps.
- Create a folder called 'Music' at the top level (root) of your USB hard drive
- Move all music on your drive into this new folder
- Once the USB drive is connected to your player, you will have the option to play all the tracks by navigating to Music Library > \[USB Drive Name\] > and pressing play on the Music folder
